Asus ROG G20CB RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
7
Past 7 Days:
34
Past 30 Days:
143
All Time:
1,014
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Upgrading or replacing the RAM (memory) on the Asus ROG G20CB can help boost system performance, especially for gaming, multitasking, or professional workloads.This guide will walk you through how to safely access, remove, and install RAM in the G20CB's compact chassis.
Important:
  • The G20CB uses DDR4 SODIMM (laptop-style) RAM, not standard desktop DIMMs.
  • Maximum supported memory depends on your CPU and motherboard model, but generally caps around 32GB (2x16GB).
Tools
    1. Asus ROG G20CB  RAM Replacement, Fan: step 1, image 1 of 2 Asus ROG G20CB  RAM Replacement, Fan: step 1, image 2 of 2
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      Ask FixBot
    2. Asus ROG G20CB  RAM Replacement: step 2, image 1 of 1
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      Ask FixBot
    3. Asus ROG G20CB  RAM Replacement: step 3, image 1 of 1
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      Ask FixBot
    4. Asus ROG G20CB  RAM Replacement: step 4, image 1 of 1
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      Ask FixBot
    5. Asus ROG G20CB  RAM Replacement: step 5, image 1 of 1
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      Ask FixBot
    6. Asus ROG G20CB  RAM Replacement: step 6, image 1 of 1
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      Ask FixBot
    1. Asus ROG G20CB  RAM Replacement, CPU Cooler: step 7, image 1 of 1
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
      Ask FixBot
    2. Asus ROG G20CB  RAM Replacement: step 8, image 1 of 1
      • Push the optical drive out of the chassis.
      Ask FixBot
    3. Asus ROG G20CB  RAM Replacement: step 9, image 1 of 1
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
      Ask FixBot
    4. Asus ROG G20CB  RAM Replacement: step 10, image 1 of 1
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
      Ask FixBot
    1. Asus ROG G20CB  RAM Replacement, RAM: step 11, image 1 of 1
      • Gently push outward on the two retaining clips on either side of the RAM stick.
      Ask FixBot
    2. Asus ROG G20CB  RAM Replacement: step 12, image 1 of 1
      • The RAM module should pop up at an angle.
      • Pull the RAM stick out carefully by grasping it by the edges.
      • Avoid touching gold contacts.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kimber-Starr
361 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 143
All Time: 1,014
