Asus L406M Touchpad Replacement
    1. Asus L406M Touchpad Replacement, Lower Case: step 1, image 1 of 3 Asus L406M Touchpad Replacement, Lower Case: step 1, image 2 of 3 Asus L406M Touchpad Replacement, Lower Case: step 1, image 3 of 3
      • Use an opening tool to remove each of the two rubber feet near the laptop hinges.
      • The rubber feet are connected using adhesive, so you'll have to use a little bit of force to get them off. If you intend to reuse the feet, take care not to warp or tear them.
      Ask FixBot
    2. Asus L406M Touchpad Replacement: step 2, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 6.4 mm-long silver screws.
      Ask FixBot
    3. Asus L406M Touchpad Replacement: step 3, image 1 of 2 Asus L406M Touchpad Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the remaining eleven 6.4 mm-long black screws securing the lower case.
      Ask FixBot
    4. Asus L406M Touchpad Replacement: step 4, image 1 of 2 Asus L406M Touchpad Replacement: step 4, image 2 of 2
      • Insert an opening pick or opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case is fully released.
      • Remove the lower case.
      Ask FixBot
    1. Asus L406M Touchpad Replacement, Battery: step 5, image 1 of 3 Asus L406M Touchpad Replacement, Battery: step 5, image 2 of 3 Asus L406M Touchpad Replacement, Battery: step 5, image 3 of 3
      • Remove the two 3.2 mm-long Phillips #0 screws that secure the battery.
      • Disconnect the battery connector cable and the speaker cable from their motherboard sockets.
      Ask FixBot
    2. Asus L406M Touchpad Replacement: step 6, image 1 of 2 Asus L406M Touchpad Replacement: step 6, image 2 of 2
      • Carefully unseat and remove the battery.
      • Take care not to bend, warp, twist, or puncture the battery.
      Ask FixBot
    1. Asus L406M Touchpad Replacement, Touchpad: step 7, image 1 of 2 Asus L406M Touchpad Replacement, Touchpad: step 7, image 2 of 2
      • Use tweezers to flip up the black locking flap securing the touchpad ribbon cable to its motherboard socket.
      • Disconnect the ribbon cable
      Ask FixBot
    2. Asus L406M Touchpad Replacement: step 8, image 1 of 2 Asus L406M Touchpad Replacement: step 8, image 2 of 2
      • Use a Phillips #00 screwdriver to remove three 2.4 mm-long screws securing the touchpad.
      • The screws in the photo strange because they were stripped. Stripped screws are caused by using the wrong tool, over-tightening the screws, or corrosion. If your screws are stripped, try using screw extracting pliers to loosen them before using the screwdriver.
      Ask FixBot
    3. Asus L406M Touchpad Replacement: step 9, image 1 of 2 Asus L406M Touchpad Replacement: step 9, image 2 of 2
      • Gently lift and remove the touchpad.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Mauricio
147 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 70
All Time: 189
