Asus Eee PC 1005HA Keyboard Replacement
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: step 2, image 1 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 2, image 2 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 2, image 3 of 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: step 3, image 1 of 2 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: step 4, image 1 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 4, image 2 of 3 Asus Eee PC 1005HA Keyboard Replacement: step 4, image 3 of 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Keyboard Replacement: step 5, image 1 of 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
Chris Beichler
579 Reputation
2 Guides authored
Cal Poly, Team 11-22, Maness Winter 2012 Member of Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 23,452
