Asus Chromebook Flip C302CA Back Panel Replacement
  1. Asus Chromebook Flip C302CA Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Back Panel Replacement: step 2, image 1 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 2, image 2 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 2, image 3 of 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Back Panel Replacement: step 3, image 1 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 3, image 2 of 3 Asus Chromebook Flip C302CA Back Panel Replacement: step 3, image 3 of 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Back Panel Replacement: step 4, image 1 of 2 Asus Chromebook Flip C302CA Back Panel Replacement: step 4, image 2 of 2
    • Remove the back panel from the laptop.
Kristen Gismondi
81,931 Reputation
200 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,161 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 132
