Asus Chromebook C300M Battery Replacement
  1. Asus Chromebook C300M Battery Replacement, Bottom Panel: step 1, image 1 of 1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Battery Replacement: step 2, image 1 of 2 Asus Chromebook C300M Battery Replacement: step 2, image 2 of 2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Battery Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Battery Replacement: step 4, image 1 of 1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Battery Replacement, Battery: step 5, image 1 of 1
    • Remove the 6.0mm Philips screws from around the battery.
  6. Asus Chromebook C300M Battery Replacement: step 6, image 1 of 1
    • Lift the battery out of the laptop.
Jake Van Loon
995 Reputation
3 Guides authored
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 86
All Time: 22,075
