Introduction
This repair guide will show you step-by-step how to remove the back casing on your Chromebook and affectively remove your battery to replace it. The process is very simple and will take you around 20 minutes to complete.
Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
Remove the eight 9.0mm Philips screws along the perimeter of the case.
Remove the three 6.0mm Philips screws from the center of the case.
Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
