Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
