Astro A50 2016 Headset Motherboard Replacement
  1. Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: step 1, image 1 of 2 Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: step 1, image 2 of 2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Motherboard Replacement: step 2, image 1 of 1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Motherboard Replacement: step 3, image 1 of 1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Motherboard Replacement: step 4, image 1 of 1
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Motherboard Replacement, Headset Motherboard: step 5, image 1 of 1
    • Remove the four 6 mm Phillips 1 screws with a screwdriver.
  6. Astro A50 2016 Headset Motherboard Replacement: step 6, image 1 of 2 Astro A50 2016 Headset Motherboard Replacement: step 6, image 2 of 2
    • Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
    • Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
    • How To Solder and Desolder Connections
  7. Astro A50 2016 Headset Motherboard Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to pry off the black tape covering the gray wires
  8. Astro A50 2016 Headset Motherboard Replacement: step 8, image 1 of 1
    • Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
Brian Menard
288 Reputation
1 Guide authored
Cal Poly, Team S15-G1, Livingston Fall 2017 Member of Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 4,084
