Arlo Pro 2 Camera Micro-USB Port Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
121
All Time:
657
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Arlo Pro 2 camera is not charging, follow this guide to walk you through the steps of replacing the Micro-USB charging port in your Arlo camera.
The Arlo Pro 2 battery usually last between 3 to 6 months on average. When battery has depleted the camera will no longer send motion captures to the connected device.
Make sure to inspect the USB port for any dirt or debris that may interfere with the connection.
Before starting this guide ensure that the camera is disconnected from any external power source.
Tools
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: step 1, image 1 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: step 1, image 2 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: step 1, image 3 of 3
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      Ask FixBot
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: step 2, image 1 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 2, image 2 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 2, image 3 of 3
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      Ask FixBot
    3. Arlo Pro 2 Camera Micro-USB Port Replacement: step 3, image 1 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 3, image 2 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      Ask FixBot
    4. Arlo Pro 2 Camera Micro-USB Port Replacement: step 4, image 1 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 4, image 2 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 4, image 3 of 3
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      Ask FixBot
    5. Arlo Pro 2 Camera Micro-USB Port Replacement: step 5, image 1 of 2 Arlo Pro 2 Camera Micro-USB Port Replacement: step 5, image 2 of 2
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      Ask FixBot
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: step 6, image 1 of 2 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: step 6, image 2 of 2
      • Thread the wires of the Micro-USB port through the casing.
      • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
      Ask FixBot
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: step 7, image 1 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 7, image 2 of 3 Arlo Pro 2 Camera Micro-USB Port Replacement: step 7, image 3 of 3
      • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
      • Gently remove the Micro-USB port by pulling it away from the case.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 Reputation
5 Guides authored
2 Guide Comments
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - Reply Share
Where can I buy the white wires?
Albert Andersen - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 121
All Time: 657
