Arlo Pro 2 Camera Lens Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
19
Past 30 Days:
70
All Time:
547
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Arlo Pro 2 camera is damaged, blurry, or not providing a video feed, follow this guide to replace the devices camera lens.
If the Arlo camera has fallen or been interfered with it may be not show a clear picture on the connected device.
Before using the guide, disconnect the Arlo Pro 2 camera from the device and power it off.
Tools
    1. Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: step 1, image 1 of 3 Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: step 1, image 2 of 3 Arlo Pro 2 Camera Lens Replacement, Camera Motherboard: step 1, image 3 of 3
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      Ask FixBot
    2. Arlo Pro 2 Camera Lens Replacement: step 2, image 1 of 3 Arlo Pro 2 Camera Lens Replacement: step 2, image 2 of 3 Arlo Pro 2 Camera Lens Replacement: step 2, image 3 of 3
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      Ask FixBot
    3. Arlo Pro 2 Camera Lens Replacement: step 3, image 1 of 3 Arlo Pro 2 Camera Lens Replacement: step 3, image 2 of 3 Arlo Pro 2 Camera Lens Replacement: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      Ask FixBot
    4. Arlo Pro 2 Camera Lens Replacement: step 4, image 1 of 3 Arlo Pro 2 Camera Lens Replacement: step 4, image 2 of 3 Arlo Pro 2 Camera Lens Replacement: step 4, image 3 of 3
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      Ask FixBot
    5. Arlo Pro 2 Camera Lens Replacement: step 5, image 1 of 2 Arlo Pro 2 Camera Lens Replacement: step 5, image 2 of 2
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      Ask FixBot
    1. Arlo Pro 2 Camera Lens Replacement, Camera Lens: step 6, image 1 of 2 Arlo Pro 2 Camera Lens Replacement, Camera Lens: step 6, image 2 of 2
      • Use a Philips #00 screwdriver to remove the four 4 mm screws on the back metal plate holding the daughterboards together.
      Ask FixBot
    2. Arlo Pro 2 Camera Lens Replacement: step 7, image 1 of 2 Arlo Pro 2 Camera Lens Replacement: step 7, image 2 of 2
      • Slide out a small metal retainer bracket from in between the daughterboards.
      Ask FixBot
    3. Arlo Pro 2 Camera Lens Replacement: step 8, image 1 of 2 Arlo Pro 2 Camera Lens Replacement: step 8, image 2 of 2
      • Pull apart the daughterboard containing LEDs from the other daughterboard.
      Ask FixBot
    4. Arlo Pro 2 Camera Lens Replacement: step 9, image 1 of 2 Arlo Pro 2 Camera Lens Replacement: step 9, image 2 of 2
      • Separate the daughterboard containing the camera piece from the metal backing.
      Ask FixBot
    5. Arlo Pro 2 Camera Lens Replacement: step 10, image 1 of 3 Arlo Pro 2 Camera Lens Replacement: step 10, image 2 of 3 Arlo Pro 2 Camera Lens Replacement: step 10, image 3 of 3
      • Use a Philips #00 screwdriver to remove the two 5 mm screws on the back of the camera daughterboard to disconnect the camera piece from the daughterboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 70
All Time: 547
