Archos 70b Stand Replacement
  1. Archos 70b Stand Replacement, Back plate: step 1, image 1 of 1
    • Remove all the tape and plugs to access the screws beneath.
  2. Archos 70b Stand Replacement: step 2, image 1 of 1
    • Unscrew all 5 of the .3mm t4 screws from the back plate of the device.
  3. Archos 70b Stand Replacement: step 3, image 1 of 1
    • Gently go around the outside of the back plate and pry the back cover off.
  4. Archos 70b Stand Replacement, Stand: step 4, image 1 of 1
    • Remove the small blocking between the battery and stand
    • Push the pin towards the battery until completely free
  5. Archos 70b Stand Replacement: step 5, image 1 of 1
    • Remove stand
    • The stand should easily slide out once the pin is removed
Joshua Stoddard
529 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Miles Fall 2015 Member of UMass Dartmouth, Team 1-3, Miles Fall 2015
UMASSD-MILES-F15S1G3
3 Members
6 Guides authored
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 8
All Time: 559
