Apple Watch Series 3 Battery Disconnection - prereq
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Apple Watch Series 3 Battery Disconnection - prereq, Battery Disconnection: step 1, image 1 of 3 Apple Watch Series 3 Battery Disconnection - prereq, Battery Disconnection: step 1, image 2 of 3 Apple Watch Series 3 Battery Disconnection - prereq, Battery Disconnection: step 1, image 3 of 3
    • Use a Y000 driver to remove the tri-point screw securing the metal cover plate.
    • Use a pair of tweezers to remove the cover plate.
    • First open the plate all the way to unhinge the two flaps.
    • Then close it halfway to remove it completely by lifting it out.
  2. Apple Watch Series 3 Battery Disconnection - prereq: step 2, image 1 of 3 Apple Watch Series 3 Battery Disconnection - prereq: step 2, image 2 of 3 Apple Watch Series 3 Battery Disconnection - prereq: step 2, image 3 of 3
    • On the GPS-only version it is possible to disconnect the battery immediately. For the cellular/LTE version, you need to disconnect the Force Touch gasket and fold it out of the way first, in order to disconnect the battery.
    • Disconnect the battery by prying its connector straight up.
    • Bend the connector up slightly to make sure it does not make contact by accident.
Tobias Isakeit
117,756 Reputation
188 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,542 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 129
