Apple Watch Series 3 Battery Disconnection - prereq
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Apple Watch Series 3 Battery Disconnection - prereq, Battery Disconnection: step 1, image 1 of 3 Apple Watch Series 3 Battery Disconnection - prereq, Battery Disconnection: step 1, image 2 of 3 Apple Watch Series 3 Battery Disconnection - prereq, Battery Disconnection: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Use a Y000 driver to remove the tri-point screw securing the metal cover plate.
    • Use a pair of tweezers to remove the cover plate.
    • First open the plate all the way to unhinge the two flaps.
    • Then close it halfway to remove it completely by lifting it out.
  2. Apple Watch Series 3 Battery Disconnection - prereq: step 2, image 1 of 3 Apple Watch Series 3 Battery Disconnection - prereq: step 2, image 2 of 3 Apple Watch Series 3 Battery Disconnection - prereq: step 2, image 3 of 3
    • On the GPS-only version it is possible to disconnect the battery immediately. For the cellular/LTE version, you need to disconnect the Force Touch gasket and fold it out of the way first, in order to disconnect the battery.
    • Disconnect the battery by prying its connector straight up.
    • Bend the connector up slightly to make sure it does not make contact by accident.
Tobias Isakeit
117,772 Reputation
188 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 130
