Introduction
Use this guide to replace the battery in your Apple Watch Series 2.
Before starting repairs, take your watch off the charger and power it down.
Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
Insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
Use a Y000 driver to remove the Tri-point screw securing the metal battery connector cover.
Remove the cover.
Disconnect the battery by prying its connector straight up with the edge of a pry tool.
Bend the connector up slightly to make sure it does not make contact by accident.
Bend the battery connector out of the way.
Use the tip of a spudger to get under the battery connector plate, which is part of the battery.
Lift the battery connector plate up and out of its recess.
Use the flat end of a spudger to get underneath the battery from the corner.
Slowly but steadily lift the battery out of the case. It is glued down with a small adhesive, so take your time.
Remove the battery.
