Introduction
Replace the hard drive in your Apple TV 1st Generation.
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
Peel and remove the hard drive up off the lower case.
Disconnect the hard drive data cable from its socket on the hard drive.
Hard drive remains.
Align the new hard drive with the screw holes on the lower case.
While holding the hard drive in place, insert and tighten the screws back into the lower case.
