Apple Powerbook 520 Floppy Drive Replacement
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: step 1, image 1 of 1
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: step 2, image 1 of 1
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: step 3, image 1 of 1
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: step 4, image 1 of 1
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: step 5, image 1 of 1
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: step 6, image 1 of 1
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: step 7, image 1 of 1
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: step 8, image 1 of 1
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Kevin Peters
130 Reputation
1 Guide authored
Cal Poly, Team 20-66, Walters Spring 2011 Member of Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Members
3 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,742
