Installing Apple IIc Floppy Drive
  1. Installing Apple IIc Floppy Drive, Disassembling Apple IIc Cover: step 1, image 1 of 2 Installing Apple IIc Floppy Drive, Disassembling Apple IIc Cover: step 1, image 2 of 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Installing Apple IIc Floppy Drive: step 2, image 1 of 2 Installing Apple IIc Floppy Drive: step 2, image 2 of 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Installing Apple IIc Floppy Drive: step 3, image 1 of 2 Installing Apple IIc Floppy Drive: step 3, image 2 of 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Installing Apple IIc Floppy Drive: step 4, image 1 of 2 Installing Apple IIc Floppy Drive: step 4, image 2 of 2
    • Lift the handle straight up to remove.
  5. Installing Apple IIc Floppy Drive, Keyboard: step 5, image 1 of 2 Installing Apple IIc Floppy Drive, Keyboard: step 5, image 2 of 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Installing Apple IIc Floppy Drive, Floppy Drive: step 6, image 1 of 2 Installing Apple IIc Floppy Drive, Floppy Drive: step 6, image 2 of 2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Installing Apple IIc Floppy Drive: step 7, image 1 of 3 Installing Apple IIc Floppy Drive: step 7, image 2 of 3 Installing Apple IIc Floppy Drive: step 7, image 3 of 3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Installing Apple IIc Floppy Drive: step 8, image 1 of 2 Installing Apple IIc Floppy Drive: step 8, image 2 of 2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Installing Apple IIc Floppy Drive: step 9, image 1 of 2 Installing Apple IIc Floppy Drive: step 9, image 2 of 2
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Installing Apple IIc Floppy Drive: step 10, image 1 of 2 Installing Apple IIc Floppy Drive: step 10, image 2 of 2
    • Lift the floppy drive straight up to remove.
Alexandria Weinberg
601 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
13 Guides authored
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 36
All Time: 5,377
