Apple IIc Floppy Drive Replacement
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: step 1, image 1 of 2 Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: step 1, image 2 of 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Floppy Drive Replacement: step 2, image 1 of 2 Apple IIc Floppy Drive Replacement: step 2, image 2 of 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Floppy Drive Replacement: step 3, image 1 of 2 Apple IIc Floppy Drive Replacement: step 3, image 2 of 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Floppy Drive Replacement: step 4, image 1 of 2 Apple IIc Floppy Drive Replacement: step 4, image 2 of 2
    • Lift the handle straight up to remove.
  5. Apple IIc Floppy Drive Replacement, Keyboard: step 5, image 1 of 2 Apple IIc Floppy Drive Replacement, Keyboard: step 5, image 2 of 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: step 6, image 1 of 2 Apple IIc Floppy Drive Replacement, Floppy Drive: step 6, image 2 of 2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Apple IIc Floppy Drive Replacement: step 7, image 1 of 3 Apple IIc Floppy Drive Replacement: step 7, image 2 of 3 Apple IIc Floppy Drive Replacement: step 7, image 3 of 3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Apple IIc Floppy Drive Replacement: step 8, image 1 of 2 Apple IIc Floppy Drive Replacement: step 8, image 2 of 2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Apple IIc Floppy Drive Replacement: step 9, image 1 of 2 Apple IIc Floppy Drive Replacement: step 9, image 2 of 2
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Apple IIc Floppy Drive Replacement: step 10, image 1 of 2 Apple IIc Floppy Drive Replacement: step 10, image 2 of 2
    • Lift the floppy drive straight up to remove.
8 other people completed this guide.
Alexandria Weinberg
601 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 37
All Time: 5,392
