Anki Vector Infrared Sensor Replacement
  1. Anki Vector Infrared Sensor Replacement, Belts: step 1, image 1 of 1
    • Raise Vector's arms above his head.
  2. Anki Vector Infrared Sensor Replacement: step 2, image 1 of 2 Anki Vector Infrared Sensor Replacement: step 2, image 2 of 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
  3. Anki Vector Infrared Sensor Replacement, Infrared Sensor: step 3, image 1 of 2 Anki Vector Infrared Sensor Replacement, Infrared Sensor: step 3, image 2 of 2
    • Pull each front wheel cover off.
    • This will require a good amount of force due to the three clips holding it in place.
  4. Anki Vector Infrared Sensor Replacement: step 4, image 1 of 2 Anki Vector Infrared Sensor Replacement: step 4, image 2 of 2
    • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
  5. Anki Vector Infrared Sensor Replacement: step 5, image 1 of 1
    • Unscrew the two body screws beneath the wheel using the same screwdriver.
  6. Anki Vector Infrared Sensor Replacement: step 6, image 1 of 2 Anki Vector Infrared Sensor Replacement: step 6, image 2 of 2
    • Gently pull off the front panel to unplug the Infrared sensor.
    • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
Shay Takei
1,570 Reputation
5 Guides authored
Cal Poly, Team S2-G6, Maness Spring 2019 Member of Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 17
All Time: 667
