Introduction
This guide will illustrate the process to remove or replace the infrared sensor of the Anki Vector. The only bit of equipment you will need to complete this guide is a screwdriver.
This guide should be helpful if your Anki Vector is having trouble distance tracking or mapping its environment.
Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
Repeat on the other side.
