Anker Soundcore Space One Battery Replacement
    1. Anker Soundcore Space One Battery Replacement, Battery: step 1, image 1 of 1
      • Flip over the device so you can see the Soundcore symbol on the back two ear pieces.
      Ask FixBot
    2. Anker Soundcore Space One Battery Replacement: step 2, image 1 of 2 Anker Soundcore Space One Battery Replacement: step 2, image 2 of 2
      • Take a strong spudger (metal or plastic) and carefully insert it into the lining between the two back ear pieces.
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one
      • Removing the cover can take a couple of minutes. However, don't be aggressive while removing it, as you could damage the interior components under the back earpiece
      Ask FixBot
    3. Anker Soundcore Space One Battery Replacement: step 3, image 1 of 3 Anker Soundcore Space One Battery Replacement: step 3, image 2 of 3 Anker Soundcore Space One Battery Replacement: step 3, image 3 of 3
      • Carefully remove the cover to reveal the battery.
      • Take a spudger and carefully lift the battery from the interior components.
      • Take care not to warp, bend, or puncture the battery.
      • The battery has a layer of adhesive under it. If necessary, use a hairdryer to lightly heat the battery to loosen the battery adhesive.
      Ask FixBot
    4. Anker Soundcore Space One Battery Replacement: step 4, image 1 of 1
      • Lift out the battery.
      Ask FixBot
    5. Anker Soundcore Space One Battery Replacement: step 5, image 1 of 1
      • Desolder the battery connections.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Malcolm Hewlett
433 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 84
Past 30 Days: 283
All Time: 2,464
