Anker Soundcore Q20i LED Diffuser Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
55
All Time:
326
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the LED indicator on the Anker Soundcore Q20i. The LED is the small light used for power, pairing, and charging status. It sits near the side button controls between the ear cup cover and the motherboard. The top of the LED fits into a holding slot in the ear cup cover that keeps it aligned with the outer light opening, while the bottom rests on the motherboard contact pads inside a small holder that provides the electrical connection. Because the LED is held in place by the cover and makes contact through the motherboard pads, it can be removed and replaced without soldering. In this guide, the LED is replaced with the same part from another used Q20i device to keep the repair simple and low cost. Before starting, power off the headphones, disconnect all cables, and work on a clean surface.
Tools
    1. Anker Soundcore Q20i LED Diffuser Replacement, Ear Pads: step 1, image 1 of 1
      • Choose the desired ear cushion to replace.
      • Orient the headphones so that the side of the ear cushion is accessible.
      Ask FixBot
    2. Anker Soundcore Q20i LED Diffuser Replacement: step 2, image 1 of 1
      • Wedge an opening tool into the groove where the ear pad meets the driver assembly.
      • Pry the ear pad away from the driver assembly.
      Ask FixBot
    3. Anker Soundcore Q20i LED Diffuser Replacement: step 3, image 1 of 3 Anker Soundcore Q20i LED Diffuser Replacement: step 3, image 2 of 3 Anker Soundcore Q20i LED Diffuser Replacement: step 3, image 3 of 3
      • Repeat Step 2 around the entire perimeter around the ear pad until it is fully detached from the base.
      • Remove the ear pad.
      Ask FixBot
    1. Anker Soundcore Q20i LED Diffuser Replacement, LED Diffuser: step 4, image 1 of 2 Anker Soundcore Q20i LED Diffuser Replacement, LED Diffuser: step 4, image 2 of 2
      • Remove the four 4.2 mm Phillips #00 screws securing the right driver assembly cover.
      • Lift the driver assembly away from the housing.
      Ask FixBot
    2. Anker Soundcore Q20i LED Diffuser Replacement: step 5, image 1 of 3 Anker Soundcore Q20i LED Diffuser Replacement: step 5, image 2 of 3 Anker Soundcore Q20i LED Diffuser Replacement: step 5, image 3 of 3
      • Identify the LED diffuser.
      Ask FixBot
    3. Anker Soundcore Q20i LED Diffuser Replacement: step 6, image 1 of 3 Anker Soundcore Q20i LED Diffuser Replacement: step 6, image 2 of 3 Anker Soundcore Q20i LED Diffuser Replacement: step 6, image 3 of 3
      • Use tweezers to gently lift the LED diffuser up out.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alamin Menu
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 55
All Time: 326
