Anker Soundcore Motion 300 Drivers Replacement
    1. Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: step 1, image 1 of 2 Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: step 1, image 2 of 2
      • Insert an opening tool into a seam between the grille and chassis.
      • Gently pry the grille up to begin disengaging the retaining clip.
      • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
      Ask FixBot
    2. Anker Soundcore Motion 300 Drivers Replacement: step 2, image 1 of 2 Anker Soundcore Motion 300 Drivers Replacement: step 2, image 2 of 2
      • Keep working around the edges until all the clips are loose.
      • You may hear soft clicking sounds as the clips come undone.
      Ask FixBot
    3. Anker Soundcore Motion 300 Drivers Replacement: step 3, image 1 of 1
      • Carefully remove the grille from the speaker.
      Ask FixBot
    1. Anker Soundcore Motion 300 Drivers Replacement, Drivers: step 4, image 1 of 3 Anker Soundcore Motion 300 Drivers Replacement, Drivers: step 4, image 2 of 3 Anker Soundcore Motion 300 Drivers Replacement, Drivers: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
      Ask FixBot
    2. Anker Soundcore Motion 300 Drivers Replacement: step 5, image 1 of 3 Anker Soundcore Motion 300 Drivers Replacement: step 5, image 2 of 3 Anker Soundcore Motion 300 Drivers Replacement: step 5, image 3 of 3
      • Use an opening tool to pry up the speaker housing.
      • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
      • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
      Ask FixBot
    3. Anker Soundcore Motion 300 Drivers Replacement: step 6, image 1 of 3 Anker Soundcore Motion 300 Drivers Replacement: step 6, image 2 of 3 Anker Soundcore Motion 300 Drivers Replacement: step 6, image 3 of 3
      • With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
      • Repeat the previous bullet for the other driver.
      • Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
      • Disconnect each of the the two driver connectors from the motherboard.
      • There may be a small piece of sealant that must be removed before the connectors can be removed.
      • Remove the drivers.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 88
All Time: 788
