Anker Soundcore Motion 300 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
112
All Time:
1,053
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Is the battery in your Anker Soundcore Motion 3000 overheating, depleting fast, or overall needs to be changed? This guide will show you how to replace the battery in your Anker Soundcore Motion 3000 Bluetooth speaker.
Check the troubleshooting pages first to confirm that your speaker needs a new battery.
Before beginning this repair, make sure to power off your speaker and unplug it from the charger.
Tools
    1. Anker Soundcore Motion 300 Battery Replacement, Speaker Grille: step 1, image 1 of 2 Anker Soundcore Motion 300 Battery Replacement, Speaker Grille: step 1, image 2 of 2
      • Insert an opening tool into a seam between the grille and chassis.
      • Gently pry the grille up to begin disengaging the retaining clip.
      • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
      Ask FixBot
    2. Anker Soundcore Motion 300 Battery Replacement: step 2, image 1 of 2 Anker Soundcore Motion 300 Battery Replacement: step 2, image 2 of 2
      • Keep working around the edges until all the clips are loose.
      • You may hear soft clicking sounds as the clips come undone.
      Ask FixBot
    3. Anker Soundcore Motion 300 Battery Replacement: step 3, image 1 of 1
      • Carefully remove the grille from the speaker.
      Ask FixBot
    1. Anker Soundcore Motion 300 Battery Replacement, Battery: step 4, image 1 of 3 Anker Soundcore Motion 300 Battery Replacement, Battery: step 4, image 2 of 3 Anker Soundcore Motion 300 Battery Replacement, Battery: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
      Ask FixBot
    2. Anker Soundcore Motion 300 Battery Replacement: step 5, image 1 of 3 Anker Soundcore Motion 300 Battery Replacement: step 5, image 2 of 3 Anker Soundcore Motion 300 Battery Replacement: step 5, image 3 of 3
      • Use an opening tool to pry up the speaker housing.
      • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
      • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
      Ask FixBot
    3. Anker Soundcore Motion 300 Battery Replacement: step 6, image 1 of 3 Anker Soundcore Motion 300 Battery Replacement: step 6, image 2 of 3 Anker Soundcore Motion 300 Battery Replacement: step 6, image 3 of 3
      • Use tweezers to remove the sealant that secures the battery connector.
      • Pull the battery connector directly out of its port.
      • Lift the battery up and out of the chassis.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 112
All Time: 1,053
