Samsung Galaxy M31 Motherboard Cover
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Samsung Galaxy M31 Motherboard Cover, Remove SIM Card Tray: step 1, image 1 of 3 Samsung Galaxy M31 Motherboard Cover, Remove SIM Card Tray: step 1, image 2 of 3 Samsung Galaxy M31 Motherboard Cover, Remove SIM Card Tray: step 1, image 3 of 3
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
  2. Samsung Galaxy M31 Motherboard Cover: step 2, image 1 of 3 Samsung Galaxy M31 Motherboard Cover: step 2, image 2 of 3 Samsung Galaxy M31 Motherboard Cover: step 2, image 3 of 3
    • Insert an opening pick between the phone assembly and the back cover at the bottom edge of the phone.
    • Slide the opening pick around the bottom right corner to release the clips holding the back cover in place.
  3. Samsung Galaxy M31 Motherboard Cover: step 3, image 1 of 2 Samsung Galaxy M31 Motherboard Cover: step 3, image 2 of 2
    • Insert a second opening pick between back cover and the phone assembly at the bottom edge of the phone.
    • Slide the opening pick around the bottom left corner to release the plastic clips holding the back cover in place.
  4. Samsung Galaxy M31 Motherboard Cover: step 4, image 1 of 2 Samsung Galaxy M31 Motherboard Cover: step 4, image 2 of 2
    • Slide the opening pick along the left side of the phone to release the plastic clips on the left side of the back cover.
  5. Samsung Galaxy M31 Motherboard Cover: step 5, image 1 of 2 Samsung Galaxy M31 Motherboard Cover: step 5, image 2 of 2
    • Slide the opening pick along the right side of the phone to release the plastic clips on the right side of the back cover.
  6. Samsung Galaxy M31 Motherboard Cover, Remove Back Cover: step 6, image 1 of 3 Samsung Galaxy M31 Motherboard Cover, Remove Back Cover: step 6, image 2 of 3 Samsung Galaxy M31 Motherboard Cover, Remove Back Cover: step 6, image 3 of 3
    • The flex cable of the fingerprint sensor is very short and the sensor is likely to disconnect itself during the following removal procedure. Avoid damaging the cable by removing the back cover too quickly.
    • Carefully lift the phone assembly out of the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before reinstalling the back cover. Be sure to power your phone back down completely before you continue working.
  7. Samsung Galaxy M31 Motherboard Cover, Unfasten Motherboard Cover: step 7, image 1 of 1
    • Remove the seven Phillips #00 screws (3.9 mm length).
  8. Samsung Galaxy M31 Motherboard Cover, Remove Motherboard Cover: step 8, image 1 of 3 Samsung Galaxy M31 Motherboard Cover, Remove Motherboard Cover: step 8, image 2 of 3 Samsung Galaxy M31 Motherboard Cover, Remove Motherboard Cover: step 8, image 3 of 3
    • Insert the tip of an opening pick underneath the top edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
    • Remove the motherboard cover.
Dominik Schnabelrauch
258,177 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,686 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 172
