Anbernic RG35XXSP Speaker Replacement
  1. Anbernic RG35XXSP Speaker Replacement, Battery: step 1, image 1 of 3 Anbernic RG35XXSP Speaker Replacement, Battery: step 1, image 2 of 3 Anbernic RG35XXSP Speaker Replacement, Battery: step 1, image 3 of 3
    • Power the device off before starting the disassembly process.
    • Close the device and turn it over so the bottom faces upward.
  2. Anbernic RG35XXSP Speaker Replacement: step 2, image 1 of 2 Anbernic RG35XXSP Speaker Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Speaker Replacement: step 3, image 1 of 2 Anbernic RG35XXSP Speaker Replacement: step 3, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Speaker Replacement: step 4, image 1 of 3 Anbernic RG35XXSP Speaker Replacement: step 4, image 2 of 3 Anbernic RG35XXSP Speaker Replacement: step 4, image 3 of 3
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Speaker Replacement: step 5, image 1 of 3 Anbernic RG35XXSP Speaker Replacement: step 5, image 2 of 3 Anbernic RG35XXSP Speaker Replacement: step 5, image 3 of 3
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Speaker Replacement, Speaker: step 6, image 1 of 2 Anbernic RG35XXSP Speaker Replacement, Speaker: step 6, image 2 of 2
    • Lift up the green sheet of paper from the motherboard.
  7. Anbernic RG35XXSP Speaker Replacement: step 7, image 1 of 3 Anbernic RG35XXSP Speaker Replacement: step 7, image 2 of 3 Anbernic RG35XXSP Speaker Replacement: step 7, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws that secure the motherboard.
    • Lift up the motherboard from the main body and flip it to the other side to reveal the speaker.
  8. Anbernic RG35XXSP Speaker Replacement: step 8, image 1 of 1
    • Remove the speaker from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 33
All Time: 230
