Anbernic RG35XXSP Motherboard Replacement
    1. Anbernic RG35XXSP Motherboard Replacement, Battery: step 1, image 1 of 3 Anbernic RG35XXSP Motherboard Replacement, Battery: step 1, image 2 of 3 Anbernic RG35XXSP Motherboard Replacement, Battery: step 1, image 3 of 3
      • Power the device off before starting the disassembly process.
      • Close the device and turn it over so the bottom faces upward.
      Ask FixBot
    2. Anbernic RG35XXSP Motherboard Replacement: step 2, image 1 of 2 Anbernic RG35XXSP Motherboard Replacement: step 2, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
      • Lift the battery door and remove it.
      Ask FixBot
    3. Anbernic RG35XXSP Motherboard Replacement: step 3, image 1 of 2 Anbernic RG35XXSP Motherboard Replacement: step 3, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 5 mm screws.
      • Lift the whole back case with the battery from the device.
      • Don't pull it away because the battery is connected to the board.
      Ask FixBot
    4. Anbernic RG35XXSP Motherboard Replacement: step 4, image 1 of 3 Anbernic RG35XXSP Motherboard Replacement: step 4, image 2 of 3 Anbernic RG35XXSP Motherboard Replacement: step 4, image 3 of 3
      • Remove the battery from the back compartment and fit it through the gap in the back case.
      • Put the plastic case aside for reassembly.
      Ask FixBot
    5. Anbernic RG35XXSP Motherboard Replacement: step 5, image 1 of 3 Anbernic RG35XXSP Motherboard Replacement: step 5, image 2 of 3 Anbernic RG35XXSP Motherboard Replacement: step 5, image 3 of 3
      • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
      • Remove the battery.
      Ask FixBot
    1. Anbernic RG35XXSP Motherboard Replacement, Motherboard: step 6, image 1 of 2 Anbernic RG35XXSP Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Lift up the green sheet of paper from the motherboard.
      • Use a Phillips #00 screwdriver to remove the three 5 mm screws from the motherboard.
      Ask FixBot
    2. Anbernic RG35XXSP Motherboard Replacement: step 7, image 1 of 2 Anbernic RG35XXSP Motherboard Replacement: step 7, image 2 of 2
      • Be careful when moving the motherboard as it is connected to the display ribbon cable, and can be damaged if pulled on.
      • Pick up the motherboard and flip it over.
      Ask FixBot
    3. Anbernic RG35XXSP Motherboard Replacement: step 8, image 1 of 3 Anbernic RG35XXSP Motherboard Replacement: step 8, image 2 of 3 Anbernic RG35XXSP Motherboard Replacement: step 8, image 3 of 3
      • Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers or your fingers to gently pull the display cable out of its socket.
      • Remove the motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
5 other people completed this guide.
1 Guide Comment
пацан, да ты провождений инженер))))) я починил свой анберник, кнопки залипали, я просто прочистил спиртом и зубной щёткой
Kolya820 - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 155
All Time: 1,160
