Anbernic RG35XXSP Action Buttons Replacement
  1. Anbernic RG35XXSP Action Buttons Replacement, Battery: step 1, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement, Battery: step 1, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement, Battery: step 1, image 3 of 3
    • Power the device off before starting the disassembly process.
    • Close the device and turn it over so the bottom faces upward.
  2. Anbernic RG35XXSP Action Buttons Replacement: step 2, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Action Buttons Replacement: step 3, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 3, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Action Buttons Replacement: step 4, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 4, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 4, image 3 of 3
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Action Buttons Replacement: step 5, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 5, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 5, image 3 of 3
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Action Buttons Replacement, Action buttons: step 6, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement, Action buttons: step 6, image 2 of 2
    • Pinch the R2 button and gently lift it to remove it.
    • Pinch the R1 button and gently lift it to remove it.
    • You will have to pull a little harder as it has a plastic pin that is connected to the body.
  7. Anbernic RG35XXSP Action Buttons Replacement: step 7, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 7, image 2 of 2
    • Pinch the L2 button and gently lift it to remove it.
    • Pinch the L1 button and gently lift it to remove it.
  8. Anbernic RG35XXSP Action Buttons Replacement: step 8, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 8, image 2 of 2
    • Use tweezers to pull the power & reset buttons up from the side of the device
  9. Anbernic RG35XXSP Action Buttons Replacement: step 9, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 9, image 2 of 2
    • Use tweezers to remove the volume buttons from the side of the case.
    • The plus side of the buttons should be closer to the back of the device.
  10. Anbernic RG35XXSP Action Buttons Replacement: step 10, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 10, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 10, image 3 of 3
    • Remove the green paper sheet from the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws from the motherboard.
  11. Anbernic RG35XXSP Action Buttons Replacement: step 11, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 11, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 11, image 3 of 3
    • Flip the motherboard over to reveal the action and directional buttons.
    • Remove the action and directional button gaskets from the motherboard.
    • In some cases, the gaskets may get stuck in the plastic case. If this happens, you can still take out the buttons like normal.
  12. Anbernic RG35XXSP Action Buttons Replacement: step 12, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 12, image 2 of 2
    • Use tweezers to remove the directional buttons from the case.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 84
All Time: 526
