Amazon Kindle Oasis 8th Gen Battery Replacement
  1. Amazon Kindle Oasis 8th Gen Battery Replacement, Back Panel: step 1, image 1 of 1
    • Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
  2. Amazon Kindle Oasis 8th Gen Battery Replacement: step 2, image 1 of 3 Amazon Kindle Oasis 8th Gen Battery Replacement: step 2, image 2 of 3 Amazon Kindle Oasis 8th Gen Battery Replacement: step 2, image 3 of 3
    • Work your way around the back panel to free all the clips.
    • There are 5 clips on the long and thickest side of the oasis, and none on the others.
  3. Amazon Kindle Oasis 8th Gen Battery Replacement: step 3, image 1 of 2 Amazon Kindle Oasis 8th Gen Battery Replacement: step 3, image 2 of 2
    • Carefully remove the back panel from the device.
    • Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
  4. Amazon Kindle Oasis 8th Gen Battery Replacement, Battery: step 4, image 1 of 1
    • Using the tweezers, lift the orange bridge connector off. Place the pliers in between the battery and the end of the bridge and lift upwards.
  5. Amazon Kindle Oasis 8th Gen Battery Replacement: step 5, image 1 of 2 Amazon Kindle Oasis 8th Gen Battery Replacement: step 5, image 2 of 2
    • Gently wedge the curved blunt face metal spudger under the battery from the left side, and slowly work the spudger around the edge of the to loosen the battery from the tape. Be careful not to rip the thin foil on the back of the battery. Once the battery is lifted around the corner, switch to the straight blunt faced spudger for easier removal
  6. Amazon Kindle Oasis 8th Gen Battery Replacement: step 6, image 1 of 1
    • Lift the battery out using the metal spudger and use your fingers to slowly pull the battery off the adhesive.
  7. Amazon Kindle Oasis 8th Gen Battery Replacement: step 7, image 1 of 2 Amazon Kindle Oasis 8th Gen Battery Replacement: step 7, image 2 of 2
    • Using the tweezers, gently lift the tape off of the Power bridge connector. If a new unit comes with a new piece of tape, remove entirely, if not remove and place one corner lightly face down on a clean surface to be used again.
  8. Amazon Kindle Oasis 8th Gen Battery Replacement: step 8, image 1 of 1
    • Once free, remove the unit from the device.
Mohamed Elzini
416 Reputation
4 Guides authored
USF Tampa, Team S16-G5, Eyestone Fall 2017 Member of USF Tampa, Team S16-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S16G5
4 Members
16 Guides authored
Past 24 Hours: 38
Past 7 Days: 253
Past 30 Days: 1,259
All Time: 46,725
