Amazon FireTV Stick Motherboard Replacement
  1. Amazon FireTV Stick Motherboard Replacement, Motherboard: step 1, image 1 of 2 Amazon FireTV Stick Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Insert a plastic opening tool into the seam on either side of the device.
    • Side the plastic opening tools along the seam of the stick and pry the top half of the case away from the bottom.
    • Don't force the case apart. If you've successfully unhooked all of the clips, the case will be easy to remove.
  2. Amazon FireTV Stick Motherboard Replacement: step 2, image 1 of 3 Amazon FireTV Stick Motherboard Replacement: step 2, image 2 of 3 Amazon FireTV Stick Motherboard Replacement: step 2, image 3 of 3
    • Lift the back of the motherboard and slide it out of the case.
Sami Uzzama
615 Reputation
2 Guides authored
IUPUI, Team 2-3, Harley SU 2016 Member of IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Members
13 Guides authored
Past 24 Hours: 14
Past 7 Days: 69
Past 30 Days: 318
All Time: 37,576
