Amazon Fire HD 8 Screen Replacement
  1. Amazon Fire HD 8 Screen Replacement, Screen: step 1, image 1 of 2 Amazon Fire HD 8 Screen Replacement, Screen: step 1, image 2 of 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Screen Replacement: step 2, image 1 of 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Screen Replacement: step 3, image 1 of 3 Amazon Fire HD 8 Screen Replacement: step 3, image 2 of 3 Amazon Fire HD 8 Screen Replacement: step 3, image 3 of 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Screen Replacement: step 4, image 1 of 3 Amazon Fire HD 8 Screen Replacement: step 4, image 2 of 3 Amazon Fire HD 8 Screen Replacement: step 4, image 3 of 3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
Dan Shimkus
1,184 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Spring 2016 Member of USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Members
17 Guides authored
Past 24 Hours: 20
Past 7 Days: 105
Past 30 Days: 451
All Time: 68,388
