Amazon Echo Show Motherboard Replacement
  1. Amazon Echo Show Motherboard Replacement, Motherboard: step 1, image 1 of 2 Amazon Echo Show Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • First, use your hands to gently remove the taped-in rubber foot from device.
  2. Amazon Echo Show Motherboard Replacement: step 2, image 1 of 1
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
  3. Amazon Echo Show Motherboard Replacement: step 3, image 1 of 3 Amazon Echo Show Motherboard Replacement: step 3, image 2 of 3 Amazon Echo Show Motherboard Replacement: step 3, image 3 of 3
    • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Visually locate the motherboard within the device. It is the large green panel right above the speakers.
  4. Amazon Echo Show Motherboard Replacement: step 4, image 1 of 2 Amazon Echo Show Motherboard Replacement: step 4, image 2 of 2
    • Unscrew the ten 1mm T5 Torx screws holding the motherboard in place.
  5. Amazon Echo Show Motherboard Replacement: step 5, image 1 of 1
    • Remove two 1mm T5 Torx screws holding down a wire connected to the motherboard.
    • Remove a small piece of black electrical tape attached to the wire.
  6. Amazon Echo Show Motherboard Replacement: step 6, image 1 of 1
    • Once all the screws have been removed, you should be able to gently lift the motherboard up and out of the device.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 24
All Time: 2,692
