Alienware M15x RAM Replacement
  1. Alienware M15x RAM Replacement, RAM: step 1, image 1 of 1
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x RAM Replacement: step 2, image 1 of 3 Alienware M15x RAM Replacement: step 2, image 2 of 3 Alienware M15x RAM Replacement: step 2, image 3 of 3
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x RAM Replacement: step 3, image 1 of 1
    • Unscrew the two screws indicated
  4. Alienware M15x RAM Replacement: step 4, image 1 of 2 Alienware M15x RAM Replacement: step 4, image 2 of 2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
7 other people completed this guide.
Gabe
8,013 Reputation
3 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,466 Guides authored
One Comment
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 24,249
