Alienware M11xR2 Display Assembly Replacement
  1. Alienware M11xR2 Display Assembly Replacement, Disconnecting Antenna Cable: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the antenna cables from the Mini-Card(s).
  2. Alienware M11xR2 Display Assembly Replacement, Removing Mimi Card: step 2, image 1 of 1
    • The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
  3. Alienware M11xR2 Display Assembly Replacement, Turning Over The Computer: step 3, image 1 of 1
    • Turn the computer over and open the display as far as possible.
  4. Alienware M11xR2 Display Assembly Replacement, Pulling The Pull-Tab: step 4, image 1 of 1
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  5. Alienware M11xR2 Display Assembly Replacement, Removing Screws: step 5, image 1 of 1
    • Remove the four screws that secure the display assembly to the computer base.
  6. Alienware M11xR2 Display Assembly Replacement, Removing Mini-Card cable: step 6, image 1 of 1
    • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
  7. Alienware M11xR2 Display Assembly Replacement, Lifting Display Assembly: step 7, image 1 of 1
    • Lift the display assembly off the computer.
  8. Alienware M11xR2 Display Assembly Replacement, Sliding New Cables: step 8, image 1 of 1
    • Slide the NEW antenna cables in through the slot on the computer base.
  9. Alienware M11xR2 Display Assembly Replacement, Securing Screws: step 9, image 1 of 1
    • Place the display assembly in position and replace the four screws that secure the display assembly to the computer base.
  10. Alienware M11xR2 Display Assembly Replacement, Connecting New Display Cable: step 10, image 1 of 1
    • Connect the display cable to the connector on the system board.
  11. Alienware M11xR2 Display Assembly Replacement, Rerouting  The Mini-Card Cable: step 11, image 1 of 1
    • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
  12. Alienware M11xR2 Display Assembly Replacement, Connecting Mini-Card Cables: step 12, image 1 of 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 449
