Alienware AW610M Motherboard Replacement
    1. Alienware AW610M Motherboard Replacement, Battery: step 1, image 1 of 3 Alienware AW610M Motherboard Replacement, Battery: step 1, image 2 of 3 Alienware AW610M Motherboard Replacement, Battery: step 1, image 3 of 3
      • Power off the mouse and disconnect any wired connections.
      Ask FixBot
    2. Alienware AW610M Motherboard Replacement: step 2, image 1 of 2 Alienware AW610M Motherboard Replacement: step 2, image 2 of 2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      Ask FixBot
    3. Alienware AW610M Motherboard Replacement: step 3, image 1 of 2 Alienware AW610M Motherboard Replacement: step 3, image 2 of 2
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      Ask FixBot
    4. Alienware AW610M Motherboard Replacement: step 4, image 1 of 2 Alienware AW610M Motherboard Replacement: step 4, image 2 of 2
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      Ask FixBot
    5. Alienware AW610M Motherboard Replacement: step 5, image 1 of 3 Alienware AW610M Motherboard Replacement: step 5, image 2 of 3 Alienware AW610M Motherboard Replacement: step 5, image 3 of 3
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      Ask FixBot
    6. Alienware AW610M Motherboard Replacement: step 6, image 1 of 2 Alienware AW610M Motherboard Replacement: step 6, image 2 of 2
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      Ask FixBot
    1. Alienware AW610M Motherboard Replacement, Motherboard: step 7, image 1 of 2 Alienware AW610M Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
      • Detach the cable connector, and remove the scroll wheel.
      • Gently detach the last connector using your fingers.
      • Be careful when unplugging all connectors to prevent tearing them.
      Ask FixBot
    2. Alienware AW610M Motherboard Replacement: step 8, image 1 of 2 Alienware AW610M Motherboard Replacement: step 8, image 2 of 2
      • Detach the blue ribbon that connects the motherboard to the shell casing.
      • Using a Phillips #1 screw driver, remove two 5.4 mm screws to detach the motherboard from the base shell casing.
      Ask FixBot
    3. Alienware AW610M Motherboard Replacement: step 9, image 1 of 3 Alienware AW610M Motherboard Replacement: step 9, image 2 of 3 Alienware AW610M Motherboard Replacement: step 9, image 3 of 3
      • Gently detach the motherboard using your fingers.
      Ask FixBot
Sherlyn Herman
97 Reputation
1 Guide authored
Texas Tech, Team 46-4, Johansen Fall 2025 Member of Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 92
All Time: 485
