Alienware 17 R4 Ram Replacement
  1. Alienware 17 R4 Ram Replacement, Base Cover: step 1, image 1 of 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Ram Replacement: step 2, image 1 of 2 Alienware 17 R4 Ram Replacement: step 2, image 2 of 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): step 3, image 1 of 3 Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): step 3, image 2 of 3 Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): step 3, image 3 of 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Ram Replacement: step 4, image 1 of 3 Alienware 17 R4 Ram Replacement: step 4, image 2 of 3 Alienware 17 R4 Ram Replacement: step 4, image 3 of 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Ram Replacement: step 5, image 1 of 3 Alienware 17 R4 Ram Replacement: step 5, image 2 of 3 Alienware 17 R4 Ram Replacement: step 5, image 3 of 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Ram Replacement: step 6, image 1 of 2 Alienware 17 R4 Ram Replacement: step 6, image 2 of 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Ram Replacement, RAM: step 7, image 1 of 3 Alienware 17 R4 Ram Replacement, RAM: step 7, image 2 of 3 Alienware 17 R4 Ram Replacement, RAM: step 7, image 3 of 3
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Ram Replacement: step 8, image 1 of 1
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
Hector Mendez III
1,280 Reputation
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 31
All Time: 2,640
