Introduction
Outline what you are going to teach someone how to do.
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Pull the base cover up to remove it.
If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
Slide the RAM card out towards yourself to remove it, while avoiding damage.
Repeat the same step for the RAM card above.
