Alienware 17 R3 Display Replacement
  1. Alienware 17 R3 Display Replacement, Display: step 1, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Flip the computer upside down.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Display Replacement: step 2, image 1 of 1
    • Unscrew and remove the two 4mm Phillips screws from cover.
  3. Alienware 17 R3 Display Replacement: step 3, image 1 of 1
    • Pull up and slide cover off.
  4. Alienware 17 R3 Display Replacement: step 4, image 1 of 2 Alienware 17 R3 Display Replacement: step 4, image 2 of 2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Display Replacement: step 5, image 1 of 1
    • Using the plastic opening tool, pull display casing away from main body.
  6. Alienware 17 R3 Display Replacement: step 6, image 1 of 1
    • Unscrew and remove the two 2mm Phillips screws from the bottom of the display.
  7. Alienware 17 R3 Display Replacement: step 7, image 1 of 1
    • Disconnect plugs connecting the display to the main body.
  8. Alienware 17 R3 Display Replacement: step 8, image 1 of 1
    • Lift display out.
Jonathon Tschurwald
830 Reputation
4 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2017 Member of UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 20
All Time: 4,238
