Alienware 17 R2 Battery Replacement
  1. Alienware 17 R2 Battery  Replacement, Battery: step 1, image 1 of 1
    • Unplug your laptop from power adapter
    • Put your laptop face down on a hard surface
  2. Alienware 17 R2 Battery  Replacement: step 2, image 1 of 3 Alienware 17 R2 Battery  Replacement: step 2, image 2 of 3 Alienware 17 R2 Battery  Replacement: step 2, image 3 of 3
    • Remove the screws on the access door
    • Pull access door up and slide off
  3. Alienware 17 R2 Battery  Replacement: step 3, image 1 of 3 Alienware 17 R2 Battery  Replacement: step 3, image 2 of 3 Alienware 17 R2 Battery  Replacement: step 3, image 3 of 3
    • Look for the black wire with the yellow tag
    • Carefully unplug the black cord with the yellow tag
    • This will successfully disconnect the battery
  4. Alienware 17 R2 Battery  Replacement: step 4, image 1 of 1
    • Disconnect the four cables from the motherboard
  5. Alienware 17 R2 Battery  Replacement: step 5, image 1 of 3 Alienware 17 R2 Battery  Replacement: step 5, image 2 of 3 Alienware 17 R2 Battery  Replacement: step 5, image 3 of 3
    • Unscrew the palm-rest screws
    • Eight 2.5mm x 8mm
    • Six 2.5mm x 10mm
    • Two 2.5mm x 18mm
  6. Alienware 17 R2 Battery  Replacement: step 6, image 1 of 3 Alienware 17 R2 Battery  Replacement: step 6, image 2 of 3 Alienware 17 R2 Battery  Replacement: step 6, image 3 of 3
    • Separate the palm-rest from the laptop
    • Disconnect the power cord from the laptop to the palm-rest
    • Remove palm-rest
  7. Alienware 17 R2 Battery  Replacement: step 7, image 1 of 1
    • Unplug the cables from the laptop
  8. Alienware 17 R2 Battery  Replacement: step 8, image 1 of 3 Alienware 17 R2 Battery  Replacement: step 8, image 2 of 3 Alienware 17 R2 Battery  Replacement: step 8, image 3 of 3
    • Remove the six 2.5mm x 5mm screws that connect the battery to the laptop
    • Gently lift up and remove battery
Past 24 Hours: 7
Past 7 Days: 55
Past 30 Days: 181
All Time: 12,280
