Alienware 15 R2 CMOS Battery Replacement
    1. Alienware 15 R2 CMOS Battery Replacement, CMOS Battery: step 1, image 1 of 3 Alienware 15 R2 CMOS Battery Replacement, CMOS Battery: step 1, image 2 of 3 Alienware 15 R2 CMOS Battery Replacement, CMOS Battery: step 1, image 3 of 3
      • Place the laptop upside down and remove the two 9 mm screws with a Phillips #0 screwdriver on the top right and top left of the back panel.
      • Remove the four 18 mm screws with a Phillips #0 screwdriver.
      • Remove the four 10 mm screws with a Phillips #0 screwdriver.
      • Remove the back cover by using the iFixit opening tool to separate it from the back of the laptop and pulling it off.
      Ask FixBot
    2. Alienware 15 R2 CMOS Battery Replacement: step 2, image 1 of 2 Alienware 15 R2 CMOS Battery Replacement: step 2, image 2 of 2
      • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Repeat for the second RAM module.
      Ask FixBot
    3. Alienware 15 R2 CMOS Battery Replacement: step 3, image 1 of 2 Alienware 15 R2 CMOS Battery Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 3 mm screw from where the RAM modules used to be.
      Ask FixBot
    4. Alienware 15 R2 CMOS Battery Replacement: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the six 6 mm screws from the back casing.
      • You can stick your finger in the hole next to the SSD slot for more space to separate the back casing from the keyboard.
      Ask FixBot
    5. Alienware 15 R2 CMOS Battery Replacement: step 5, image 1 of 1
      • Lift the keyboard off of the frame of the laptop.
      Ask FixBot
    6. Alienware 15 R2 CMOS Battery Replacement: step 6, image 1 of 1
      • Using your fingers, disconnect the TRON light cable from the motherboard.
      Ask FixBot
    7. Alienware 15 R2 CMOS Battery Replacement: step 7, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the three 6 mm screws securing the battery.
      Ask FixBot
    8. Alienware 15 R2 CMOS Battery Replacement: step 8, image 1 of 1
      • Using your fingers, lift the battery out of the laptop's body.
      Ask FixBot
    9. Alienware 15 R2 CMOS Battery Replacement: step 9, image 1 of 1
      • Use a Phillips #0 to remove screws from the motherboard.
      Ask FixBot
    10. Alienware 15 R2 CMOS Battery Replacement: step 10, image 1 of 1
      • Using your fingers, pull out the motherboard.
      Ask FixBot
    11. Alienware 15 R2 CMOS Battery Replacement: step 11, image 1 of 1
      • Disconnect and remove CMOS battery.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
jesse
220 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 68
All Time: 412
