Alcatel Go Flip 4 Camera Replacement
    1. Alcatel Go Flip 4 Camera Replacement, Camera: step 1, image 1 of 1
      • Heat the screen cover with an iOpener to soften the adhesive holding it to the display frame.
      Ask FixBot
    2. Alcatel Go Flip 4 Camera Replacement: step 2, image 1 of 2 Alcatel Go Flip 4 Camera Replacement: step 2, image 2 of 2
      • Insert a Jimmy under the screen cover to pry it open.
      Ask FixBot
    3. Alcatel Go Flip 4 Camera Replacement: step 3, image 1 of 3 Alcatel Go Flip 4 Camera Replacement: step 3, image 2 of 3 Alcatel Go Flip 4 Camera Replacement: step 3, image 3 of 3
      • Use plastic opening picks to separate the adhesive.
      • Add more heat as needed.
      Ask FixBot
    4. Alcatel Go Flip 4 Camera Replacement: step 4, image 1 of 2 Alcatel Go Flip 4 Camera Replacement: step 4, image 2 of 2
      • Remove the plastic screen cover and set it aside.
      Ask FixBot
    5. Alcatel Go Flip 4 Camera Replacement: step 5, image 1 of 1
      • Remove the four 3.5 mm screws holding the rear cover in place using a JIS #00 screwdriver.
      Ask FixBot
    6. Alcatel Go Flip 4 Camera Replacement: step 6, image 1 of 2 Alcatel Go Flip 4 Camera Replacement: step 6, image 2 of 2
      • Starting at the hinge side, insert the Jimmy between the rear cover and the display's frame.
      • Continue down the side of the phone, releasing clips as you go.
      Ask FixBot
    7. Alcatel Go Flip 4 Camera Replacement: step 7, image 1 of 3 Alcatel Go Flip 4 Camera Replacement: step 7, image 2 of 3 Alcatel Go Flip 4 Camera Replacement: step 7, image 3 of 3
      • Work your way across the bottom and up the other side to separate the rear cover from the rest of the phone.
      Ask FixBot
    8. Alcatel Go Flip 4 Camera Replacement: step 8, image 1 of 2 Alcatel Go Flip 4 Camera Replacement: step 8, image 2 of 2
      • Disconnect the camera flex cable with the spudger.
      Ask FixBot
    9. Alcatel Go Flip 4 Camera Replacement: step 9, image 1 of 3 Alcatel Go Flip 4 Camera Replacement: step 9, image 2 of 3 Alcatel Go Flip 4 Camera Replacement: step 9, image 3 of 3
      • Remove the camera from the display using tweezers.
      Ask FixBot
Dulcemaria Ramirez
641 Reputation
5 Guides authored
Texas Tech, Team 2-2, Johansen Fall 2025 Member of Texas Tech, Team 2-2, Johansen Fall 2025
TTU-JOHANSEN-F25S2G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 200
