Honda 6500 Watt Generator EG6500CL AT Safety Precautions
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
21
All Time:
94
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Perform these safety steps before you work on the Honda 6500 Watt Generator EG6500CL AT.
    1. Honda 6500 Watt Generator EG6500CL AT Safety Precautions, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: step 1, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Safety Precautions, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: step 1, image 2 of 2
      • Before you work on the device, make sure to switch the engine off.
      • Switch the circuit breaker off.
      Ask FixBot
    2. Honda 6500 Watt Generator EG6500CL AT Safety Precautions, Disconnect the spark plug: step 2, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Safety Precautions, Disconnect the spark plug: step 2, image 2 of 2
      • Grab the plastic housing at the end of the spark plug wire.
      • Pull firmly to disconnect the wire from the spark plug.
      Ask FixBot
    3. Honda 6500 Watt Generator EG6500CL AT Safety Precautions: step 3, image 1 of 2 Honda 6500 Watt Generator EG6500CL AT Safety Precautions: step 3, image 2 of 2
      • Twist the fuel valve clockwise into the cutoff position.
      Ask FixBot
Finish Line
Arthur Shi
351,542 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 94
