Air Hog Smash Bots Radio Receiver Replacement
  1. Air Hog Smash Bots Radio Receiver Replacement, Batteries: step 1, image 1 of 1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Radio Receiver Replacement: step 2, image 1 of 1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Radio Receiver Replacement: step 3, image 1 of 1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Radio Receiver Replacement, External Casing: step 4, image 1 of 2 Air Hog Smash Bots Radio Receiver Replacement, External Casing: step 4, image 2 of 2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Radio Receiver Replacement: step 5, image 1 of 2 Air Hog Smash Bots Radio Receiver Replacement: step 5, image 2 of 2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Radio Receiver Replacement: step 6, image 1 of 1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Radio Receiver Replacement: step 7, image 1 of 1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Radio Receiver Replacement: step 8, image 1 of 2 Air Hog Smash Bots Radio Receiver Replacement: step 8, image 2 of 2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: step 9, image 1 of 2 Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: step 9, image 2 of 2
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Air Hog Smash Bots Radio Receiver Replacement: step 10, image 1 of 2 Air Hog Smash Bots Radio Receiver Replacement: step 10, image 2 of 2
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Brittany Frecker
542 Reputation
4 Guides authored
IUPUI, Team 1-1, Baechle Spring 2016 Member of IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 283
