Introduction
This outline will guide you to replace the radio receiver, if it happens to break will in use. A soldering iron will need to be used for this, directions on how to solder can be found here.
Use the plastic opening tool to pry the front and back of the lower body apart.
Carefully remove the back of the bot from the front.
