Introduction
In this replacement guide, you will remove and install a RAM module.
Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
Once completely unscrewed, carefully lift the cover off.
Place the screw and cover safely to the side for now.
Tool used on this step:Anti-Static Wrist Strap$7.95
Now take your anti-static wrist strap and place it tightly on your wrist.
Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
Locate the RAM module.
Squeeze the two metal clips on the sides of the RAM module to pop the RAM out.
Carefully remove from the slot.
