Acer Chromebook C710-2833 RAM Module Replacement
    1. Acer Chromebook C710-2833 RAM Module Replacement, RAM Module: step 1, image 1 of 1
      • Flip your Chromebook over so the bottom is facing up.
      Ask FixBot
    2. Acer Chromebook C710-2833 RAM Module Replacement: step 2, image 1 of 2 Acer Chromebook C710-2833 RAM Module Replacement: step 2, image 2 of 2
      • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
      • Once completely unscrewed, carefully lift the cover off.
      • Place the screw and cover safely to the side for now.
      Ask FixBot
    3. Acer Chromebook C710-2833 RAM Module Replacement: step 3, image 1 of 2 Acer Chromebook C710-2833 RAM Module Replacement: step 3, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Now take your anti-static wrist strap and place it tightly on your wrist.
      • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
      • The location chosen in the picture is recommended.
      Ask FixBot
    4. Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 1 of 3 Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 2 of 3 Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 3 of 3
      • Locate the RAM module.
      • Squeeze the two metal clips on the sides of the RAM module to pop the RAM out.
      • Carefully remove from the slot.
      • When reassembling, stick RAM into slot and push down until a clicking sound is heard.
      Ask FixBot
Nicholas Latorre
558 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Nance Fall 2017 Member of USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 104
All Time: 1,384
