Acer Chromebook C710-2833 RAM Module Replacement
  1. Acer Chromebook C710-2833 RAM Module Replacement, RAM Module: step 1, image 1 of 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 RAM Module Replacement: step 2, image 1 of 2 Acer Chromebook C710-2833 RAM Module Replacement: step 2, image 2 of 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 RAM Module Replacement: step 3, image 1 of 2 Acer Chromebook C710-2833 RAM Module Replacement: step 3, image 2 of 2
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 1 of 3 Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 2 of 3 Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 3 of 3
    • Locate the RAM module.
    • Squeeze the two metal clips on the sides of the RAM module to pop the RAM out.
    • Carefully remove from the slot.
    • When reassembling, stick RAM into slot and push down until a clicking sound is heard.
Nicholas Latorre
558 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Nance Fall 2017 Member of USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 803
