Introduction
This guide will walk you through replacing the SSD in your Acer Chromebook 15 CB5-571-C09S.
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
