Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: step 1, image 1 of 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 2, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 2, image 2 of 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 3, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 4, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 4, image 2 of 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: step 5, image 1 of 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: step 5, image 2 of 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: step 5, image 3 of 3
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 6, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: step 6, image 2 of 2
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
Sakiynah Howard
1,000 Reputation
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 40
All Time: 3,283
