Introduction
How to replace a faulty motherboard in your Acer Aspire V5-473P-5602 notebook.
Keep yourself grounded to avoid shocking your components by using an anti-static mat. If you don't have one, simply go barefoot while standing on a hard surface floor while working on your motherboard. Socks cause static. Don't forget to disconnect the power!
Taking photos after you complete each step will help you keep up with where the components should be while you're working.
Flip the laptop over so the back panel is facing upwards.
Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
Remove the back panel from the laptop using an iFixit opening tool.
Remove the two Phillips #0 screws that secure the fan to the base.
Remove the fan from the laptop.
Unplug the two data cables that attach the keyboard to the motherboard.
Remove the motherboard from the laptop.
